Car needs to be FASTER!!!!
Old Jun 26, 2004 | 06:34 PM
BlackBird97's Avatar
Unhappy Car needs to be FASTER!!!!
After doing the latest mods, I have come to the conclusion...I need to go faster. I have pretty much done every free mod available, and done almost every other mod. "See Sig" What can I do to my car to give it better top end, and mid range?! Besides No2, Turbo, Blower. or any totally insain engine rebuild. I am trying to keep my car NA. Any input would be great.
Old Jun 26, 2004 | 06:45 PM
simple's Avatar
4.10 gears
different cam
3000+ stall converter
remove the front sway bar, tremendously helps with weight transfer, allowing the front to rise more under accelleration (the feel of going faster)
Old Jun 26, 2004 | 07:35 PM
)2overt SS's Avatar
Is that true? Hmmm.. I may have to look into removing mine.. I never understood why people removed theirs..
Old Jun 26, 2004 | 08:07 PM
djk19's Avatar
I wouldn't even think of taking off my sway bar. It would make youir car so sloppy in the turns....
Unless you drive it just at the track dont take off the S.B.
Old Jun 26, 2004 | 10:15 PM
Haskin Z28's Avatar
my car handles fine without the front sway bar
Old Jun 26, 2004 | 10:27 PM
1racerdude's Avatar
Car WILL be fine with no sway bar and 90/10's if you want.I don't suspect you will be showing up at Luguna Seca in the near future.
Old Jun 27, 2004 | 12:58 AM
PatriotTA's Avatar
Ditto. Even with my swaybar long gone, my TA handles better than any other car I have driven (except a friends WRX ). Chances are you will forget you don't have a swaybar unless you are doing some serious autocross.
Old Jun 27, 2004 | 01:14 AM
krispy's Avatar
ported heads, you will see the most gain there
Old Jun 27, 2004 | 01:35 AM
96lt1Camaro's Avatar
BlackBird97, how fast are you? dont see any numbers down.
Old Jun 27, 2004 | 02:37 AM
314 rwhp 300.7 torque... ...It just doesn't seem right
Old Jun 27, 2004 | 04:45 AM
97WS6SCharged's Avatar
Those numbers seem right if you're at the altitude I'm thinking.
I'd say ported heads with a bigger cam and a PCM reflash.
Old Jun 27, 2004 | 09:59 AM
96speed's Avatar
Its not as bad as you think. If you are just driving around normally you won't really notice its off until you put it back on and think "oh yeah, this is what its supposed to feel like" .
Ryan
Old Jun 27, 2004 | 06:10 PM
simple's Avatar
Ryan
exactly
i have tubular k-member and a-arms and it still handles fine
it could be better with the front sway bar
but all in all its not like taking it off turns the car into a bus or something
ModdedNerd
Dec 10, 2014 08:42 PM
USAirman93
Nov 24, 2014 03:37 PM
Black93lt1
Nov 21, 2014 07:30 PM
Jul 4, 2005 05:00 PM
Brian Demeter
Aug 21, 2002 02:07 PM
