Car is missing and running like crap...
Old Mar 6, 2004 | 09:17 AM
SlickLT1's Avatar
Exclamation Car is missing and running like crap...
Need your help again guys...I just dont get it. Ok my 94 Z28 Auto with 117k is missing under acceleration and you can also feel it miss slightly while cruising. I replaced the opti about a month ago because it was damn near gone. The car does not idle like crap like it used too when the opti was bad. But I did get a coolant spill on it right after I replaced it. DOH! It seems to be alright though. Is there a possibility that the plugs could be causing this. I havent replaced them since I have owned the car. 95k And I have no idea when they were last changed.
Everything else appears to be fine with the car...good oil pressure, temp, etc. It just misses while under acceleration. It seems to be most noticable after the engine warms up. Thanks for helpin guys and gals.
Thanks again, Cory
Old Mar 6, 2004 | 10:22 AM
93turboTA's Avatar
I had a similar problem and it turned out to be one of my wires had melted a little
Old Mar 6, 2004 | 10:31 AM
Robs97Z28's Avatar
plugs will hard starting, missfiring, rough idle, just to name a few. replace wires and plugs would be the first thing I would do with those kinda miles...then go from there..
97SSdude
Dec 31, 2014 07:43 PM
USAirman93
Nov 24, 2014 03:37 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
MJ_Z28
Aug 7, 2002 07:15 PM
