Car Making Noise When Turning Left
Old Mar 21, 2004 | 04:07 PM
My Mighty White 95 Z28's Avatar
Question Car Making Noise When Turning Left
Hey everybody, I just notice my car when turning left it makes this noise which sounds like when your brake pads needs to be changed. Also the sound appears sometimes when I am just driving normally. The noise is more noticeable and is a little bit louder when turning left. But when turning right no noise. I was wondering if anybody would be able to give me any suggestions or ideas on what I should check. Thanks in advance for your help.
Old Mar 21, 2004 | 04:49 PM
snksknr94's Avatar
Check you motor mounts. I had a similar problem ended up being that my left mount was so shot that the head of the bolt was rubbing on the head of another bolt making a very noticable clicking sound when braking or turning left.
Old Mar 21, 2004 | 04:51 PM
RamAir95TA's Avatar
Can you identify where the noise is coming from? If it's from the rear of the car, you might have a worn posi unit or rubbing/sticky brake caliper.
Old Mar 21, 2004 | 05:44 PM
1982z28with18s's Avatar
PM hyperspeed (he has some #'s in his name also but I can't remember it exactly) He had the same problem and fixed it awhile back. I think it was due to worn out c-clips.
Old Mar 21, 2004 | 05:52 PM
5.7LT1Formula's Avatar
check your A arm on the side making the noise. there is a nut on the bottom that may be "wallard" out some. put a wrench on it and crank it down. its a 3/4 or 11/16 i think?
Old Mar 21, 2004 | 10:11 PM
Lightbulb
Thanks for the help, I forgot to mention that the noise is coming from the front driver side tire.
Old Apr 5, 2004 | 11:35 AM
SATANAZ666's Avatar
me too
Im haveing the exact same problem....
Anyone fix it??
Old Apr 5, 2004 | 12:21 PM
RicocheT's Avatar
Mine makes a popping noise everynow and then when turning left.. I looked and everything appeared OK. Hadn't heard it in a while but then again, I hadn't driven it either.
Old Apr 6, 2004 | 05:38 PM
SATANAZ666's Avatar
NOISE
MIGHT IT BE THE POWER STEERING PUMP??? OR THE BRAKES?????/ Anyone out there know??
Old Apr 6, 2004 | 06:15 PM
Cool
Hey everybody, sorry for the delay in replying sooner but 2 weeks ago, I put my car on jacks and pulled off my front driver side tire and found out the little indicator on the brake pad in which it tells you that you need to change your brake pads, was touching the rotor. So I went ahead and bought a pair of front rotors and pads. After installing the pads and rotors, I took the car for a test drive and there was no noise at all. I was so glad it was the pads and not anything else. So before buying anything, check your brake pads first and go from there. If you have any questions please feel free to e-mail me. Thanks.
Old Apr 7, 2004 | 09:48 AM
SATANAZ666's Avatar
THANK YOU SOOOO MUCH
tHANKS SOOOO MUCH FOR GIVING US AN UPDATE!!! I definitely was in need of the information as I developed this noise just last week. Well seems this weekend I will change the pads and rotors along with te shocks, balljoints, tie-rod ends....hahaha Seems like I have a weekend planned.
Old Apr 7, 2004 | 11:56 PM
EaC95Z28's Avatar
to snk94 i think my problem might be the motor mount. its a pretty loud clicking noise when turning the wheel and braking sometimes its a loud click. does anyone know what it might be, doesnt do ti while drivin only while going slow or slowind down to a stop, put new pads and rotors on about 10k ago so dont thiink thats it. plus it did it b4. i hate it i hope nothing majjor is wrong ima try to get it checked out. if anyone can help please do!
Old Apr 11, 2004 | 10:55 PM
snksknr94's Avatar
look at the driver side motor mount. You'll be able to see the 2 bolts I'm talking about.
jj71787
Dec 30, 2014 02:15 PM
CaRParts102
Dec 6, 2014 08:45 AM
ro2207
Dec 4, 2014 06:18 PM
NewsBot
Dec 3, 2014 12:30 PM
USAirman93
Nov 24, 2014 03:37 PM
