Car just turns over...
Old Nov 12, 2007 | 02:36 PM
CANTONRACER's Avatar
Strange issue with my car....
I swapped the stock opti-spark last week. Car started fine and ran fine for 10 minutes...stalled for no reason and ended up being a stuck starter that seized.
Replace that...and put on the headers, exhaust, accessories and get it rewired.
Fires up and ten seconds later...stalls.
Strange fuel issue that was fixed with a faulty relay that came with the racetronix kit.
I have spark, I have fuel...yet it just turns over and does not fire up. All sensors are clean...wires are in good shape...there is no reason at all the car is not firing up.
I just wonder now if the Accel opti-spark has failed or the timing is off? All the plugs were fouled out something fierce....cleaned them up and even took air pressure to the combustion chambers to dry them out.
Plugs are not fouling now....good fuel psi...spark...so could it be the timing of the spark?
Any thoughts?
Old Nov 12, 2007 | 04:12 PM
Guest47904's Avatar
Guest
Easiest way to tell is put number 1 at TDC and pull the cap off the distributor. The rotor should be pointing near the 6 oclock position.
Old Apr 28, 2008 | 01:00 PM
I replaced my failed opti that was completely destroyed (yet short shifted and ran times in sig), with an Accel opti-spark.
Last week I replaced the replacement (the Accel) with a stock OEM opti and guess what, the car started up.
Who would have guessed.....
Old Apr 28, 2008 | 01:20 PM
96' Formula WS6's Avatar
Yea I dont think accel has figured out the opti spark situation because there has recently been alot of complaints on them. Good to know, I almost bought one.
Old Apr 28, 2008 | 04:31 PM
marshall93z's Avatar
Glad you got it going!
Old Apr 28, 2008 | 09:33 PM
Bersaglieri's Avatar
The general get's it right again. I have had good luck with my new AC Delco units.
-Dustin-
liamcg97
Nov 25, 2019 05:55 PM
jj71787
Dec 30, 2014 02:15 PM
CaRParts102
Dec 6, 2014 08:45 AM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
