Car intermittent start, Weak/no noid light
Old 03-16-2016, 09:35 AM
  #16
walt355's Avatar
Re: Car intermittent start, Weak/no noid light
Ok wanted to give an update. After bypassing the cut off switch, changing batteries, extra cables, grounds and a new LT4 starter I still had the trouble. Got a tune for the car and it has yet to not start since, Even if the battery is weak and is draggy cranking it will still start in a couple spins. After digging in the old tune the injectors were set on 42lb, However I have 36 lb. Now it makes sense. The PCm may have not fired the injectors enough for starting if set like this, but I may be wrong. Either way it starts and runs good now. Thanks
walt355 is offline
bfmv13trivium
01-14-2015 09:57 AM
fpete1992
12-11-2014 03:51 PM
blac94Z
12-02-2014 12:09 PM
USAirman93
11-24-2014 03:37 PM
Dave19yz28
01-26-2003 01:45 PM
Quick Reply: Car intermittent start, Weak/no noid light
