Car has 6 codes @ one time
Old Jan 9, 2004 | 11:02 PM
818camaro95's Avatar
Question Car has 6 codes @ one time
I went to start my car and it started to shake and had no power. I turned it off for a minute and started it up and now I have 6 codes on my Scanmaster codes.
18 Injector circuit(s)
36 Distributor ignition system (faulty high resolution pulse or extra low resolution pulse
41 Ignition Control (IC) circuit (open circuit)
42 Ignition Control (IC) circuit (shorted or grounded circuit)
46 Pass-Key®II circuit
68 A/C relay circuit (shorted circuit)
What would cause all these codes to come up @ one time. I have a 95 Z
Old Jan 9, 2004 | 11:40 PM
terlox's Avatar
Which fuses blew?
Old Jan 9, 2004 | 11:56 PM
Originally posted by terlox
Which fuses blew?
I have no idea, would that cause the codes?
Old Jan 10, 2004 | 12:39 PM
ChickenScreamer94's Avatar
check under the hood at the fuse juntion box (driver side) and pull each fuse out and see if any are blown, especially those injector one (7.5) there are two of em. Then on the inside check for blown fuses (driver side again).
Whats your voltage at?
If all is ok and it just started doing this, maybe your pcm took a poopey.
Old Jan 10, 2004 | 01:45 PM
turbo_Z's Avatar
clear them and see if it happens again. looks like an opti problem to me though.
Old Jan 10, 2004 | 08:12 PM
I checked all the fuses and there fine. It started yesterday, do you mean battery voltage? It's fine.
Old Jan 11, 2004 | 09:00 AM
Up.
Old Jan 11, 2004 | 09:50 AM
slopokrodrigez's Avatar
Low battery voltage caused your problem. Either battery or connections.
Old Jan 11, 2004 | 02:41 PM
I removed the pcm fuse and the codes are gone. I took it for a 20 minute drive no codes. So what could of happend?
Noenav
Mar 1, 2019 07:38 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
blac94Z
Dec 2, 2014 12:09 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
