the car finally runs, slight issue though
Old Jul 9, 2012 | 02:20 AM
96z28_lt1's Avatar
Hey guys i finally got my car running almost right now after 11 months of it being apart and redone. The problem is when driving the cars rpms hang at like 2000 rpm with clutch pressed in and not in gear, when stoping teh rpms don't drop until almost a complete stop, also idle is about 100 rpms i've seen it 300 rpms higher then its suppose to be car was tuned for 825 i believe and its idling around 900ish sometimes even touching 1100 before it drops back down. I tried the IAC from the guide off shbox and it brought the pms down to 900 when before they were 1100ish. Also driving at low speeds(i've only had the car up to 40mph so far) it bucks under little to no throttle sometimes worse then others is this cam surge i'm not quite sure because this is my first cam, or if its related to the other problems. Thanks for the help!
Old Jul 9, 2012 | 03:16 AM
my1994z28's Avatar
Re: the car finally runs, slight issue though
Have you had the car tuned yet?...Every "camed"car I have had they all surged when the rpms were under 2000 rpms....Congrats on geeting your running and on the road..
Old Jul 9, 2012 | 09:44 AM
96z28_lt1's Avatar
its got a tune from mad tuner, runs a little rich but i hear thats expected, just trying to figure out why the rpms are hanging at about 2grand when i presss in clutch its kind of annoying, and thanks its great to drive her again.
Old Jul 23, 2012 | 04:42 PM
A2GrLT1's Avatar
Have you checked for a vacuum leak?
Old Jul 23, 2012 | 07:32 PM
parkers Z28's Avatar
possible that the throttle cable is sticking or the spring that works it maybe a little
rusty from sitting??? congratulation on you build I'm sure your going to be happy
with it once you get the bugs worked out. i think there is a throttle position sensor
also scan for codes.
Old Jul 23, 2012 | 10:08 PM
saylorz28's Avatar
sounds like an auto pcm on a stick to me ... my 90 z did the same thing until i got a chip burnt for it to swap from auto to stick ... could be a mix up with the tune .. i've seen stranger things
jayblev95
Jan 20, 2015 01:30 PM
ChrisFrez
Dec 7, 2014 06:01 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
