Car Dies When it's Very Hot and Humid Outside
Old Jul 13, 2013 | 12:13 PM
pboxfun's Avatar
Exclamation Car Dies When it's Very Hot and Humid Outside
I've recently noticed a problem with my car and I'm trying to see if it's tune related or electrical. Maybe you can help point me in the right direction. The problem I'm having is my car stalls in gear at idle, like at stop light or waiting to make a turn. It will start up again but it sometimes takes awhile of trying. Weird part about this problem is that it only happens when it's very humid out especially after a rain storm. Other than when it's humid outside the car runs just fine and has no problems. It never dies on me while I'm driving either or misses. I did notice before the car shuts off the rpms act very erratic almost a 500 rpm variation. But when it's not humid out the rpm acts like it should. The only way I can keep it from dieing at stop is by pressing the throttle raising the rpms up while holding the brake with my other foot.
A couple months ago I installed a new opti, plugs, wires (otvc), alternator, and battery. The icm and coil has less than 5k miles on it since I've replaced them. I checked the fuel pressure to make sure it wasn't the pump and it was fine. Also there isn't any codes being thrown at all when this happens.
Does anyone have any idea what could be going on? Any help would be greatly appreciated!
Old Jul 13, 2013 | 02:44 PM
slick1hunting's Avatar
might be worth looking under the hood in the dark to see if you get a light show or any arcing. Might also be worth trying to use a spray bottle to simulate the humidity. Water or moisture will sometimes cause the electrical signal to jump or change path following the path of least resistance so to speak. Might have a knicked or split or burned wire or bad connector but perhaps more common bad plug wires.
Posted from Camaroz28.com App for Android
Old Jul 14, 2013 | 01:26 PM
pboxfun's Avatar
Re: Car Dies When it's Very Hot and Humid Outside
Good idea I'm going to try that and see what happens.
bfmv13trivium
Jan 14, 2015 09:57 AM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
teedoff59
Aug 8, 2002 01:36 AM
