car cuts out up top
Old Jan 30, 2006 | 03:59 PM
Mustang4Lunch2's Avatar
car cuts out up top
sometimes while getting on my car at about 5k it cuts out for a split second like a rev-limiter than it keeps pulling. sometimes it does it twice. was wondering what could be causing this?? if anyone has similar problems please let me know what you found it out to be.
Old Jan 30, 2006 | 04:54 PM
bstieboydp's Avatar
Re: car cuts out up top
my dads car had this similiar problem sounded like it was farting/misfiring up high it turned out to be the fuel filter was clogged hopefully thats your problem cheap and you can do it yourself in 10 minutes if you dont mind alil gas
Old Jan 30, 2006 | 04:59 PM
RacingTiger04's Avatar
ive heard of that being the opti before, but i have to go with bstieboydp on this one. i use to have the same problem, changed my fuel filter just because i didnt know when it had been changed last and havent noticed it doing that since then. so for $15 and a little bit of time its definately worth checking .. sure beats jumping straight for the opti..
Old Jan 30, 2006 | 05:05 PM
oh i know it's not my opti don't have one bob baily coil pack kit and got rid of the opti. running a seperate crank position sensor modified to work w/ the ltcc kit. hehe
Old Jan 30, 2006 | 09:38 PM
lol ur not kiddin in ur sig are ya :P, bet thats a nice setup. ah well good luck then let us know how things turn out with the fuel filter. be interesting to see what you find causes this cause most places ive seen always list it as an opti symptom, theyll love to hear this one lol.
Old Jan 30, 2006 | 09:46 PM
6SpdLT1Z's Avatar
werd, I came in here to suggust that it sounded like a opti.
Old Jan 30, 2006 | 10:42 PM
haha ya sorry guys that it's not the opti. gonna change the fuel filter 2morrow just changed it like 5 months ago and this is not a everday car but never know.
Old Jan 31, 2006 | 01:03 AM
Wckd94Z's Avatar
fuel pump
Old Jan 31, 2006 | 03:39 PM
have a walboro that is only 2 yrs. old 255lph could it be dying pre maturaly also car is running kinda rich.
Old Feb 2, 2006 | 05:43 PM
bstieboydp's Avatar
im in suspense here man let us know what happened how did the fuel filter swap work out ??
Old Feb 2, 2006 | 05:47 PM
rmackintosh's Avatar
...arcing spark plug wire...
Old Feb 2, 2006 | 10:12 PM
swapped it out but, need a new tire on the front so will get that swapped than tell you guys.
Old Feb 3, 2006 | 10:12 AM
slow96z's Avatar
When I was having that problem it turned out to be a bad coil. Maybe one of your coil packs are bad?
Old Feb 3, 2006 | 03:05 PM
could be but they are all 8 brand new oem coil packs. is there a way to test them w/ a meter or anything of that nature??
Old Feb 3, 2006 | 04:33 PM
slow96z's Avatar
the way I tested mine was to install a new one. Sorry!
