Caprice Lt1
Old Sep 10, 2003 | 06:41 AM
ProtoX's Avatar
Caprice Lt1
Will a 4 bolt block from a caprice work in my 95 Camaro?
Old Sep 10, 2003 | 07:05 AM
IXLR894Z28's Avatar
I believe that it is the same engine found in Z28's. Should work fine.
Old Sep 10, 2003 | 08:45 AM
Xscream's Avatar
A caprice motor should be a 2 bolt but GM has done strange things. It also comes with cast heads, not alu... If I recall the motor is rated for 260ish instead of the 280ish that would be found in a camaro. Heads are swapable if you have a set, it wouldn't be a bad idea.
Old Sep 10, 2003 | 09:13 AM
IrocManiac's Avatar
Heads should swap...but 4 bolts in a caprice??? I do believe they were 2 bolts unless GM just screwed up on a few which is entirely possible.
Old Sep 10, 2003 | 12:10 PM
ProtoX's Avatar
It is a 4 bolt. So I can use heads off my current 95 Z? Is there no other differences?
Old Sep 10, 2003 | 02:12 PM
Xscream's Avatar
There is a differnce in the heads but your Z28 heads will bolt right up.
Old Sep 10, 2003 | 02:30 PM
IrocManiac's Avatar
He's exactly right there is a difference in the heads and how they'll perform but they will bolt right up.
Old Sep 10, 2003 | 03:55 PM
ProtoX's Avatar
Thanks for the help. I think I will go ahead and buy that block.
Old Sep 10, 2003 | 04:39 PM
RamAir95TA's Avatar
A Caprice block is a 4-bolt block.
Old Sep 11, 2003 | 07:51 PM
arnie's Avatar
Hmmmmm. Since when, and what years?
Old Sep 11, 2003 | 07:56 PM
scoobysnax83's Avatar
we think alike young Grasshopper....
Geezz, how many Caprice's do you see just sitting in the junk yard
Old Sep 11, 2003 | 08:29 PM
arnie's Avatar
Again, I'd like you to offer evidence/proof, which I trust you have. This isn't just more internet hearsay?
Old Sep 11, 2003 | 09:09 PM
AndyB's Avatar
NOPE. And the pic to prove it
http://www.jbelectric.us/ot/ImpalaSS...bottomend2.jpg
Taken during an oil pump swap a few weeks ago.
Old Sep 11, 2003 | 09:10 PM
http://www.jbelectric.us/ot/ImpalaS.../bottomend2.jpg
so where did you get that info from RamAir? Maybe its certain years.... Where you at to defend you honor?
Old Sep 11, 2003 | 09:20 PM
Originally posted by SSlammedlt-4
Honestly it looks like a two bolt block to me, But who knows I am blind.
well, the one in the pic is, thats why were trying to get RamAir to fill us in. Maybe GM did it in certain years....
