CamaroZ28.Com Message Board
-   -   Canton Oil pan question (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/canton-oil-pan-question-500048/)
arcticz28the383 Feb 3, 2007 09:32 AM
I know you can take out the stock oil pan with the engine in the car, put could I install Canton with the engine in the car? I wasnt able to install a windage tray because of my 383 setup and I ran out of funds (stupid i know) but know that I got the money Im just trying to figure out the easiest way to do it. Has anyone tried dropping the cradle and supporting the motor from above?
TQdrivenws6 Feb 5, 2007 09:18 AM
I have taken my canton out and put it back in a couple times with the engine in the car yet. I just drop the K-frame and support the engine with my hoist. When you install the canton, put it in without a gasket once and turn it over by hand. More than likely you will need to clearance the scraper. Also watch the gasket, I have to trim the flange where the rod bolts pass.
94/96ZsM6s Feb 5, 2007 02:44 PM
make sure you only put 6 quarts of oil in the system(5qts in pan, 1qt for the oil filter, if using a full quart filter). oil level will be on the bottom twist of the dip stick. don't put 8 in like i did....especilly with a 383.....
