Cant set TPS up with holley TB.
Old Oct 24, 2003 | 01:07 PM
96z's Avatar
96z
I had a TB gasket and multiple vacumme leaks that I fixed and in the process I gave the TB a good cleaning. I took the TPS off and now I keep getting a low voltage code on startup. I know what the target voltage is and I cant get anywhere inbetween .2 and .9. I slotted the TPS put it on the TB, moved it all over the place and the voltage will barely move and only up to .13 volts. The TPS itself is brand new and the voltage varies when I manipulate it with a screwdriver.
I do have the throttle stop set from before I took the TB off. Should I let that all the way down and try again?
Anyone have any advice?
Potent77
Mar 16, 2022 12:13 AM
HectorM52
Jul 30, 2017 11:46 AM
A's 91 Z28
Jan 11, 2015 10:58 AM
Queens94z28
Dec 20, 2014 09:11 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
