Can't rev engine and pieces coming from exhaust
Old Aug 20, 2007 | 10:37 PM
mrmint69's Avatar
Question Can't rev engine and pieces coming from exhaust
My friends car will barely idle. It is hard to rev it at all. The exhaust has black smoke and there are pieces on the ground after its sits idling and the attempting to rev it some. I think cat but maybe someone has a better idea. Thanks in advance. It appears to be running rich if this helps.
Old Aug 20, 2007 | 11:16 PM
Stl94LT1's Avatar
Sounds like the rich condition has clogged the cat.
Old Aug 21, 2007 | 01:29 AM
96m6lt1's Avatar
your cat(s) sound to be clogged and breaking appart inside and firing off into your muffler,disconnect your y-pipe before the cat and see if it runs better
Old Aug 21, 2007 | 01:52 AM
1bad94z28's Avatar
Get a soft mallet and lightly tap on the cat to see if it rattles like there are alot of little pieces in it. This happen to me but it only rattled and did not spit out chunks. The guy that replaced my cat said that since my car was lowered the cat gets splashed by water and it is very hot so this heat/cold breaks down the material inside and it was the orginal cat, so he said. Good luck
Old Aug 25, 2007 | 04:59 PM
mrmint69's Avatar
No cat. I thought that too until i looked under the car.
Old Aug 25, 2007 | 05:20 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Was the cat recently removed because it was plugged? If so, chunks of the cat could have blown back into the exhaust. This happened to me.
Old Aug 25, 2007 | 08:30 PM
mrmint69's Avatar
Well i looked under the car and could barely see anything. Its 3" off the ground and noticed nothing. I then jacked it up and found the cat. The thing is not where it was from the factory so i was looking in the wrong place. I had cut the exhaust pipe in the rear right before the muffler and started the car. I got chunks as big as quarters! I then stuck an old FMU on that i had for my car and ran it with that. The difference was night and day. It would not run unless you kept the gas pedal down. It now runs at 1500-2000 rpm but it idles 5 times better without any gas. I figured the fmu was stuck close and no fuel would return to the tank. No black smoke at all and it sounds smooth. It is still on the rich side so i will replace the cat and muffler and go from there. Thanks all for the help
oldschool
Feb 9, 2016 09:21 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
Dec 4, 2014 11:56 AM
