Can't get Tranny on?
Old Nov 20, 2003 | 02:42 PM
Heatmaker's Avatar
Advanced Member
Ok...here's my question I wiggled the Tranny into the Bell housing...but I got like a half inch gap. Just enough to screw the Clutch fork back in, but the Tranny wont go any further. I can't seem to get it in all the way. I mounted the Tranny to Bell housing bolts and began turning some of them. The Gap slowly started to Decrease....before I continue with this..is that the proper way to get this back on right?
Old Nov 20, 2003 | 04:30 PM
Heatmaker's Avatar
Advanced Member
Anyone
Old Nov 20, 2003 | 05:33 PM
Javier97Z28's Avatar
Moderator
It doesn't sound like you have the clutch/flywheel properly aligned and the input shaft is having trouble sliding in. Make sure you have used an alignment tool and that it can slide in/out easily.
Old Nov 20, 2003 | 05:52 PM
drewstealth's Avatar
Well it is not the proper way of doing it. But i myself had to do it that way. I took everything off and put it back on 4 times. Everytime it would get about 1/4 inch away from the bellhousing. Just try to take it off 1 more time just to make sure everything is lined up really good. If everything is good and it still doesn't go all the way just make sure you turn all the bolts equally. With little turns. Good luck.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
