Cant Get Differential Fill plug off
Old Sep 30, 2003 | 08:32 PM
WhiteBeast's Avatar
Exclamation Cant Get Differential Fill plug off
Ok, the fill plug looks like it might be rusted on. What are some options on getting it off?
Old Sep 30, 2003 | 08:45 PM
mc63's Avatar
Just use a long 3/8" extension.
Old Sep 30, 2003 | 09:03 PM
Bud M's Avatar
Try PB Blaster to loosen up the rust.
Old Sep 30, 2003 | 09:12 PM
WhiteBeast's Avatar
Thanks,
I guess i will just put it on the lift tomorow and try to torque it off.
Thanks Again
Old Sep 30, 2003 | 09:37 PM
gearheads78's Avatar
What he said.....The best stuff ever.
Spray, wait a couple min.
Tap with a ball peen a couple times.
Spray again.
Wait 5 min and remove plug.
I don't ever have to break out the torch since this stuff came around.
Old Sep 30, 2003 | 10:38 PM
95BlackTA's Avatar
I found it easier without the use of an extension...jes got a 3/8" wrench, and put the end in there...I had to presss the button to get it in there, otherwise it wouldnt get in there all the way.
Old Sep 30, 2003 | 10:55 PM
94 CAMRO Z28's Avatar
What he said, then just use a "cheater bar" on the end of your 3/8" wrench. Or if you have a breaker bar with a 3/8" end to it that would work well too. Pop the end in and give a good yank. Actually I did the same thing on the drain plug for my tranny but it was so tight that I had to position myself under it and just give the wrench a good kick to get it broken loose.
Aaron
Old Sep 30, 2003 | 10:58 PM
scoobysnax83's Avatar
just crank that sumnabitch.....
F'n1996Z28SS
Aug 23, 2023 11:19 PM
warmeck
Apr 16, 2015 05:53 PM
Sandersen511
Jan 13, 2015 03:49 PM
CR97WS6
Aug 17, 2002 12:12 AM
