Can't find the AIR pump connector?
I'm putting my engine back in and I can't find the second connector for the air pump. I connected the shorter one but can't find the thats looks like a fuel injector connector. I looked at shoebox's main wire harness picture and I dont see it there either.
The purge valve for the AIR pump won't work. (I am assuming you are looking for the connector that goes to the valve on the coil stud)
It helps keep moisture out of the pump (the cause of failure of the original pumps).
If you took the connector off, just keep looking. It has to be there.
CamaroZBoy
Sep 9, 2002 10:33 AM
CamaroZBoy
Sep 1, 2002 09:48 AM
