cant figure it out !
Old Feb 15, 2007 | 02:37 PM
finalstage1's Avatar
i have a 95 firebird formula , motor is all stock . ok heres my problem
sometimes it will start and run like **** then after about 2-3 min it will die
then sometimes it will not start at all .
i scanned it and got a code 43 , the wire was not all the way on ths knock sensor . i put the wire on and started it and it still ran like crap . i cleared the code and let it run until it died and the code did not come back .
could this posible be a problem with the coil and the icm ?
Old Feb 15, 2007 | 02:47 PM
It could be a problem with a lot of things. There is just not enough data there to tell. Check all obvious stuff for connection and fitment, first.
Old Feb 15, 2007 | 02:49 PM
mrmint69's Avatar
Have you checked the fuel pressure?
Old Feb 15, 2007 | 03:38 PM
im waitig for my fuel presure tester to get here . i thought that might be the problem so i ordered one , i thought it would be here by now .
Old Feb 15, 2007 | 04:57 PM
2000GTP's Avatar
You could have gone to your local Sears or auto parts store and snagged one for 30 bucks.
Old Feb 15, 2007 | 05:24 PM
i know i could have bought one local then i would not have to wait , but my nervous system is a little messed up so its kinda hard for me to walk so it was easier for me to just order it .
Old Feb 15, 2007 | 11:07 PM
i put a new fuel filter in my car and it started up but still ran like crap . so i just started looking around and testing a few thing . i found out that 1,2,6,7 injectors do not have 12v power . is my pcm bad or where should i start ? sorry the info is so vague i just need a place to start .
Old Feb 16, 2007 | 07:01 AM
The PCM does not provide voltage to the injectors. There are two fuses to 4 each of the injectors, but what you say has no voltage is mixed between the fuses. If it was 2,3,5,8 or 1,4,6,7 it would likely be a fuse. Maybe you really mean 1,4,6,7.
Old Feb 16, 2007 | 12:12 PM
i checked the fuses and they are good im going to check the wire coming out the bottom of the fuse box . how do you get the bottom off the fuse box ,and is it the wire pink ?
thank you for all your help .
Old Feb 16, 2007 | 01:03 PM
There are some tabs you have to release to get the fuse box apart, IIRC. Yes, the power wires to the injectors are pink. If it is really 1,2,6,7 (you did not confirm) that don't have power, the problem is not going to be on the common feed from the fuse.
http://shbox.com/1/smfi_devices_injectors.jpg
Old Feb 16, 2007 | 02:12 PM
you were wright shoebox it is 1467 that dont have power . i took the fuse box bottom off and the two injector fuses have power going in and power coming out , but there is no 12v at the injector . so what do i do now ?
Old Feb 16, 2007 | 04:18 PM
shoebox , when the wire comes off the number 9 fuse where does it go ? the books and wiring digrams say it goes directly to the injector , but i traced it a little and it looks like it goes somewhere over by the pcm .
Old Feb 16, 2007 | 06:23 PM
ttt . need help !!!!!!!!!
Old Feb 16, 2007 | 10:14 PM
Did you look at the schematic link I posted? It shows it going through C100 cavity "A". That may be where your open is. It would be the next logical place to check. Here is a pic of where C100 is (ignore the fan switch notations).
Please be fair and heed the TTT rules posted in the sticky at the top of the forum.
Old Feb 16, 2007 | 10:21 PM
Guest47904's Avatar
Guest
Fuse 10 is the circuit you want
1,4,6&7 are fed from fuse #10 in the underhood fuse panel. It feeds a pink wire that goes through connector C100. It's a black 10 pin connector near the PCM. The confusing part is, both the wires for fuse 9 and fuse 10 are next to each other on one end of the connector. The one you want to look at is on the same side as the latch.
From that connector the pink wire goes to a splice S102 which is located about 5 cm from injector #3. From there is splits off to the 1,4,6 &7 injectors.
Obviously if the fuse is good, the wire is broke somewhere between the fuse panel and the splice. Good place to start is the connector. Perfect 1/2 way point.
