cant figure it out !
i have a 95 firebird formula , motor is all stock . ok heres my problem
sometimes it will start and run like **** then after about 2-3 min it will die
then sometimes it will not start at all .
i scanned it and got a code 43 , the wire was not all the way on ths knock sensor . i put the wire on and started it and it still ran like crap . i cleared the code and let it run until it died and the code did not come back .
could this posible be a problem with the coil and the icm ?
i know i could have bought one local then i would not have to wait , but my nervous system is a little messed up so its kinda hard for me to walk so it was easier for me to just order it .
i put a new fuel filter in my car and it started up but still ran like crap . so i just started looking around and testing a few thing . i found out that 1,2,6,7 injectors do not have 12v power . is my pcm bad or where should i start ? sorry the info is so vague i just need a place to start .
i checked the fuses and they are good im going to check the wire coming out the bottom of the fuse box . how do you get the bottom off the fuse box ,and is it the wire pink ?
thank you for all your help .
There are some tabs you have to release to get the fuse box apart, IIRC. Yes, the power wires to the injectors are pink. If it is really 1,2,6,7 (you did not confirm) that don't have power, the problem is not going to be on the common feed from the fuse.
http://shbox.com/1/smfi_devices_injectors.jpg
you were wright shoebox it is 1467 that dont have power . i took the fuse box bottom off and the two injector fuses have power going in and power coming out , but there is no 12v at the injector . so what do i do now ?
shoebox , when the wire comes off the number 9 fuse where does it go ? the books and wiring digrams say it goes directly to the injector , but i traced it a little and it looks like it goes somewhere over by the pcm .
Please be fair and heed the TTT rules posted in the sticky at the top of the forum.
Fuse 10 is the circuit you want
1,4,6&7 are fed from fuse #10 in the underhood fuse panel. It feeds a pink wire that goes through connector C100. It's a black 10 pin connector near the PCM. The confusing part is, both the wires for fuse 9 and fuse 10 are next to each other on one end of the connector. The one you want to look at is on the same side as the latch.
From that connector the pink wire goes to a splice S102 which is located about 5 cm from injector #3. From there is splits off to the 1,4,6 &7 injectors.
Obviously if the fuse is good, the wire is broke somewhere between the fuse panel and the splice. Good place to start is the connector. Perfect 1/2 way point.
