cannot remove opti..hub is in the way
Old Feb 9, 2014 | 04:37 PM
blackblur1996z28's Avatar
I go to remove my old opti and there isny enough room to slide it out. The crankshaft hub is blocking it. From what ive read on here and the web is that only the pulley needs to come off not the hub. Do I have to remove the hub as well or am I missibg something? Please any help is appreciated.
Old Feb 9, 2014 | 04:42 PM
bw_hunter's Avatar
Re: cannot remove opti..hub is in the way
If you have the pulley off all you have to do is rotate the engine until the notch in the hub allows the opti enough clearance...
Good luck
Old Feb 9, 2014 | 05:08 PM
Got it off! Thanks!
greenzee28
Sep 25, 2015 04:29 PM
Jake Bialke
Sep 24, 2015 11:31 AM
wbspoon
Sep 19, 2015 08:12 AM
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
