can youy overtighten oul pan bolts?
Old May 23, 2010 | 11:29 PM
z28beast's Avatar
soo i have the blue felpro oil pan gasket and i just got done installing it without any rtv silicone just like felpro says... i tightened the bolts to about as tight as i could get them and im wondering if its gonna cause any problems.... i know that felpro has those little spacers in there gaskets but what would happen if i crushed one of them? i really really dont want any oil leaks! think im ok or should i redo it?
Old May 23, 2010 | 11:33 PM
ajenks_32's Avatar
As long as your not close to stripping out the bolts you should be alright
Old May 23, 2010 | 11:38 PM
z28beast's Avatar
i dont think so but i have a feeling that there around like 35=-50ft lbs
Old May 24, 2010 | 12:05 AM
ajenks_32's Avatar
If you have those spacers I would definally listen to beast ^^^^^
for some reason i couldn't read your info on the post the first time
Old May 24, 2010 | 03:29 AM
MikeGyver's Avatar
Tighten them till they break then back em out 1/4 turn.
Old May 24, 2010 | 05:12 AM
z28beast's Avatar
was there a point to that or are you just stupid?
Old May 24, 2010 | 05:30 AM
Look at Shoebox's fastener guide. Side bolts are 106 pound-inch. That's less than 9 pound-foot.
http://shbox.com/ci/fastener_matrix.html
Old May 24, 2010 | 08:22 AM
wrd1972's Avatar
They do not get very tight or the gasket will fail or the pan will mis-conform. They get barely snug and they are good to go.
Old May 24, 2010 | 09:29 AM
paxtonLT1's Avatar
yea i didnt trust my torque wrench so i did like 25 ft lbs and it leaks.... now i gota drop the sub frame to fix it.
Old May 24, 2010 | 09:32 AM
"As tight as you can get them" is way too tight.
Old May 24, 2010 | 09:37 AM
dangalla's Avatar
i cant imagine why there is only a few people left that are willing to even post in your threads, at the rate your going you wont be getting any replies soon. you need to relax with the insults, you asked a stupid question and deserved a stupid answer. if you need someone to tell you that "as tight as you can go" is to freaking tight i cant image why you would be building your own motor
it was a joke, no need to insult anyone.
Old May 24, 2010 | 10:13 AM
RamAir95TA's Avatar
This guy works backwards...buying things THEN asking for advice on parts selection...tightening things THEN asking for torque specs. I don't get it.
Old May 24, 2010 | 02:58 PM
I sense the same frustration that many of you are feeling - but we can't turn this into a "dump on z28beast" thread. If you don't have a constructive contribution, please don't post. Eventually, if enough people stop posting, because they feel their info is not helpful or not being listened to, there will be no point in additional posts. At that point, the advice will be "seek the assistance of an experienced engine builder".
I think most people have shown a great amount of patience with this member. Let's not let it go down hill now.
Old May 24, 2010 | 06:05 PM
Dave1980's Avatar
I would suggest just getting the torque specs for LT1 engine bay and taping them to a wall in your garage or to side of toolbox. It seems a common thing of reference to me at least. This will help you when in doubt about specs. It seems sometimes you have to learn the hard way then you start to listen to do things right. Its the will to do a good job that brought you to the forum to learn, and that is the start to becoming better than what you are.
Some guys will chunk a joke in, but you have to laugh, or ignore. Even the most knowledgeable here can be an *** sometimes.
The felpro put the spacers in there so you dont crush the gasket. If you feel you overtightened them just back them off and go with the proper spec. If you have a leak, go from there.
Old May 24, 2010 | 06:29 PM
Some bolts (like for the auto transmission oil pan) will be damaged/ruined (integrated cupped washers) if over-tightened. Others (water neck bolts come to mind) can snap off easily. So, it's best to know the spec, before you tighten them to heck.
