Can you tap a bolt in the head?
Old May 10, 2008 | 05:48 PM
94YellowTAGT's Avatar
Some how i messed up a bolt on number 8. I have moved the header out of the way and tried to thread the bolt in with no success. The bolt wants to go crooked every time. I stop before i get to far so i don't think there is major damage. Can i use a tap with the head on the? If so can i use the same size bolt?
Old May 10, 2008 | 06:11 PM
Dave1980's Avatar
Go to sears hardware, and get a thread repair kit (red case). It is not a tap kit, but repair kit. They basically reform the metal without cutting into the material. They are good for cleaning up threaded holes also.
The kit is around 50 bucks, but it has lots of sizes and you will use it again and again. I have used it in your situation, and also in my engine buildup for cleaning bolts and threads.
Even if you used an actual cutting tap, your probably only going to need to use it for the first 1/4 inch of the actual threaded hole on #8. It is likely the rest of the threads are ok. In situations like that it is good to stop your self before you jack something up, trying to make things happen.
Old May 10, 2008 | 06:20 PM
Thanks for the tip. I will try the repair kit. I have tried it serval times but i always stop because it is just crooked.
Old May 11, 2008 | 12:48 AM
mrmint69's Avatar
I usually find that when the bolt does what you describe the thing is not lined up or isn't sitting flush. I usually start over and start with that one and make sure they all start before proceding.
Old May 11, 2008 | 09:12 AM
This worked perfect. I got the threads cleaned up and threaded the bolt in three times before i put the header back in place. It all went great.
That is why this place is best!
Old May 11, 2008 | 10:18 AM
Dave1980's Avatar
Great! Glad I could help. Same thing happened to me a while back.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
Roadie
Feb 16, 2015 10:34 AM
rcajun86
Jan 30, 2015 01:56 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
