Can you run .560 lift safely on stock pistons with 54cc heads??
Old Jan 22, 2008 | 05:13 PM
95NX-TA's Avatar
I am asking this question because I have a cam with .525 lift with 1.5 rockers and I want to put 1.6 rockers to increase the lift to .560. The heads are a set of ported edelbrock lt1's with 54cc. I heard that I should be okay usually up to .600 lift without any clearance issues. Does anyone have any experience or input before I have to put clay on the piston and check it for myself??
Thanx
Old Jan 22, 2008 | 05:26 PM
Colin91Z's Avatar
Everyone's combo will differ, so it's always a good idea to check.
With that being said, I've used a cam with .568 lift on an LT1 that had stock pistons, 52cc combustion chambers, and thinner impala SS head gaskets with no clearance issues at all
Old Jan 22, 2008 | 05:31 PM
mdacton's Avatar
it depends on the camshaft, where its installed etc. Lift doesn't matter iff the piston is further down the cyl.
I run a little lift with a 50.9 cc chamber,.005 deck and .040 gasket and have .080 PTV
LeftoverChinese
Jan 14, 2024 03:03 PM
Feffman
Oct 9, 2015 05:42 AM
skittlez87
Dec 29, 2014 03:23 PM
squarehead
Nov 21, 2014 08:02 PM
