Can you replace just the lifters?
Old May 8, 2005 | 03:14 PM
Huntr1117's Avatar
My lifters are getting louder and louder. I tried adjusting the rocker arms, but the noise is still there. Can you replace just the lifters? My car has 115K miles. If I only replace the lifters will it effect my cam in any bad way? What all do I have to do to replace them? Pull the intake and the rocker arms?
Old May 8, 2005 | 08:54 PM
Huntr1117's Avatar
Re: Can you replace just the lifters?
Old May 8, 2005 | 09:07 PM
Robs97Z28's Avatar
yes, you can just replace your lifters, with no bad effects. use only stock replacement like comp cam 850-16 or cranes 10530-16 ...
Old May 8, 2005 | 09:08 PM
The Cartel's Avatar
Yea you can replace them. I have a set of factory ones out of my car. They have 40k miles on them. If you want them I'll ship'em to ya for 50.00. You just need to remove the intake and rockers like you said. Easy job, will in no way effect your cam...
Jason
Old May 8, 2005 | 09:31 PM
Huntr1117's Avatar
I don't know if I should replace them with a used set or not. Has anyone ever done that before? Is it recomended? I saw this http://www.barkerengines.com/tip052202.htm . Does anyone know were I can get a detailed description on replacing the lifters?
Old May 8, 2005 | 10:03 PM
Robs97Z28's Avatar
I would only go new. the cranes are only $190 at summit. going cheap on valve train parts can cost you big money, if anything fails.
The link only applies only to flat tappet. you have roller lifters. ajust install them the same way the old lifters come out.
Old May 8, 2005 | 11:18 PM
Huntr1117's Avatar
Are the lifters that parts stores sell any good? Or do I have to go with the Comps or Crains?
Old May 9, 2005 | 03:35 AM
The Cartel's Avatar
Are you ever planning on doing a cam swap, or rebuild in a few years? If so, why spend the money on new lifters now, when your going to replace it all in the future. Hyd. Roller lifters don't wear like a flat tappet.
lmk. Jason
HectorM52
Jul 30, 2017 11:46 AM
Sauced
Apr 12, 2015 10:18 AM
dfarr67
Apr 10, 2015 07:44 PM
jj_burchiel
Mar 5, 2015 07:05 AM
jayblev95
Dec 1, 2014 06:55 AM
