Can a stuck caliper cause Brake and ABS lights to come on?
I've had these lights on for a few days. I've done a search and tried all the ideas the treads offered, with no luck. I put my car up and spun the wheels, all turned freely except the front right, very hard to turn. The car also pulls to the LEFT on braking. Before I pay an hours worth of trouble shooting at a shop. I was wondering, could the line be clogged to that wheel causing a pressure misbalance, throwing the codes. Or possibly, stuck slide pins or piston. I'm not losing any fluid, so I doubt there is a broken line or pistion skirt. I'm going to try and pull the cailper apart to see if I can find anything. Any ideas would be appericated.
carguy0119
Apr 11, 2016 11:11 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
