can in stall..did the cam fall down when putting it in?
Old Feb 20, 2006 | 10:05 AM
TransAm396's Avatar
when you guys installed your cam..did it drop down? mine did almost every time..and now im afraid i might of knicked the bearings..i did it very lightly...but i want to make sure.
Old Feb 20, 2006 | 10:16 AM
97bowtie's Avatar
Re: can in stall..did the cam fall down when putting it in?
It will fall down if you don't hold it firm and straight, and even then it can get away from you a little bit. This is why you want to go very slow and rotate the cam on it's way in. As long as you weren't forcing it in once it 'fell', then you are probably OK. The cam will click and clank a little on it's way in/out, even if you are real careful.
Old Feb 20, 2006 | 10:23 AM
TransAm396's Avatar
oh i was very very careful..i used cam lube too...and there was no forcing...every once and a while...i had to twist the cam cuz it wouldnt go in..but i put it in very gently..but i couldnt help it falling in whenever it would get past the bearings...but itseemed to go in fine..i was just nervous..im not sure how easy it is to nick the bearing.
Old Feb 20, 2006 | 12:17 PM
Jeff95TA's Avatar
It would be nice if engine stands could be rotated vertically, then you could slide the cam straight down.
Or if you could make gravity horizontal......
Old Feb 20, 2006 | 12:56 PM
TransAm396's Avatar
haha hell yeah..
Old Feb 20, 2006 | 03:47 PM
97WS6NY's Avatar
Hey man let me know how that 847 works out for you. I agree, if you didn't forced it a worked slow you will be fine.
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Queens94z28
Nov 20, 2014 06:03 PM
