Can someone post a pic of the inside of a stock oil pan
Old Oct 19, 2006 | 08:47 PM
snakeatinZ's Avatar
I bought one off the board and was wondering what the windage tray looks like, or what the inside of one looks like that is ready to bolt on the motor? So can someone post a pic or discribe what their's looks like?
thanks,
Steve
Old Oct 19, 2006 | 08:53 PM
Javier97Z28's Avatar
Moderator
Re: Can someone post a pic of the inside of a stock oil pan
There's no windage tray inside the stock oil pan, the stock windage tray bolts is held on by a stud/bolt combo for the mains by 3 nuts.
Old Oct 19, 2006 | 09:06 PM
ulakovic22's Avatar
It looks like a normal pan with a little plate welded parallel to the ground where the curve is about 3-4 inches over the deep part, and then the windage tray is bolted to the studs. If you are going with aftermarket rods you might have to clearance or remove the windage tray cause the rod bolts will hit.
http://www.karl-ellwein.org/3507b.jpg
Old Oct 19, 2006 | 10:17 PM
Pan pic.
Old Oct 20, 2006 | 04:55 PM
snakeatinZ's Avatar
thank you so much guy's!!!
Steve
HectorM52
Jul 30, 2017 11:46 AM
Jlo
Feb 3, 2015 09:41 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
