Can Someone name these parts?
Old Oct 2, 2005 | 06:13 PM
Brian89T's Avatar
Just finished replacing the intake gasket and found some hoses that were rotted. I need some help finding the proper name and if they are dealer only items. First one is the rubber hose that comes off the pcv valve, the second hose is on the right side of the throttle body; second one from the top.
Also, do you guys think this rotted hoses would cause the throttle to stick at all. That was a problem that I hope the hoses will fix
Brian
Old Oct 2, 2005 | 06:15 PM
Re: Can Someone name these parts?
Just as you would tell someone at a parts counter what car you had to get parts, the same applies here if you want help.
Old Oct 2, 2005 | 06:25 PM
Brian89T's Avatar
Sorry, 97 Z28
Old Oct 2, 2005 | 07:50 PM
FastZinTennessee's Avatar
I don't see any reason that those hoses would cause the throttle to stick...... You need to get some spray carb cleaner, and clean the area around the throttle blades on the throttle body.
Old Oct 3, 2005 | 06:08 PM
3gc's Avatar
3gc
I replaced the PCV hose before, mine was cracked at the ends. It was $15 at the dealer, part number 10128365.
Old Oct 3, 2005 | 07:00 PM
Brian
The small piece of hose that is right on the PCV does not have a part number. It is just a short, straight piece of hose.
The hose on the right side of the TB is in this diagram. Sounds like the one you mean goes to the EVAP solenoid.
Old Oct 3, 2005 | 09:44 PM
3gc's Avatar
3gc
Sorry, the part number I gave was for the hose from the passenger valve cover to the throttle body, not the PCV. And i didn't realize 97 was different, disregard my previous post.
Old Oct 3, 2005 | 10:25 PM
OldSStroker's Avatar
George and Zachary.
Old Oct 3, 2005 | 10:31 PM
Originally Posted by OldSStroker
George and Zachary.
Good as any, lol!
HectorM52
Jul 30, 2017 11:46 AM
novaiiman
May 15, 2016 11:36 AM
oldschool
Feb 9, 2016 09:21 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
