Can someone ID this connector?
Old May 28, 2005 | 07:58 PM
toadies101's Avatar
My ABS INOP light has been on since I bought the car. I thought it was a burnt spoiler light bulb. I was wrong, then I noticed this connector tucked up under the CAI. I dont know if its related to my ABS problem but I do remeber something that was attached to the stock air box a long time ago when I had my TA, like a little black box, but cant remember what it did. I think this is where this connector goes but not positive. Can someone please trace these wires and tell me where they go.. It comes off the harness under the ABS stuff and is in the same bundle as the fan wires then the fan wires go one way and the this goes the other. These pictures were taken under the air filter and under the driver side air dam.. Any clues?? Thanks, Brandon
http://www.itsaz.com/connector/con1.JPG
http://www.itsaz.com/connector/con2.JPG
http://www.itsaz.com/connector/con3.JPG
Old May 28, 2005 | 08:05 PM
94 NO TOP Z's Avatar
Re: Can someone ID this connector?
Might be for the cruise control. Have you still got that hooked up?
Old May 28, 2005 | 08:06 PM
oneslowz28's Avatar
looks like a abs sensor plug but i could be wrong ill look tomorrow and let ya know
Old May 28, 2005 | 08:08 PM
toadies101's Avatar
That very well could be, someone before me took the cruise off for some reason. Now does the cruise control unit need to be present for the ABS to work properly since the cruise can be deactivated by braking??
Old May 28, 2005 | 08:11 PM
toadies101's Avatar
There is a wiring harness similar to the one pictured on the side closest to the fender plugged into the side of the ABS stuff.. I read on a post that there is a connector underneath the ABS stuff but I couldnt find one there..hmmmm
Old May 28, 2005 | 10:29 PM
Ryan94ZA4's Avatar
Definitely Cruise Control....
Check your ABS codes and you'll know what's wrong. Have to have someone with a scantool that reads ABS codes as they don't read off of regular engine code.
Ryan
Old May 28, 2005 | 10:56 PM
toadies101's Avatar
Thanks Ryan, that makes sense since the cruise control isnt there, a friend of mine works at a stealership i'll have him scan the ABS comp.
Anyone want to sell their underhood cruise control stuff??
Old May 28, 2005 | 11:05 PM
Ryan94ZA4's Avatar
I should have a couple cruise boxes laying around. I'll check and let you know. All you need is the box and the bracket it mounts to.
Ryan
Old May 28, 2005 | 11:23 PM
toadies101's Avatar
that and the cable that goes to the throttle and the motor is missing too. Thanks again! I appreciate it
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Double aught
Oct 2, 2015 11:29 PM
autoxr166
Sep 25, 2015 04:21 PM
frankrizz
Sep 23, 2015 04:21 PM
