can PCM adjust for 28lb injectors?
Old Feb 8, 2004 | 01:14 PM
med_reject's Avatar
Cool can PCM adjust for 28lb injectors?
Neartest PCM dyno tuner is hundreds of miles away. If I put 28lb injectors in a head cam lt1, woudl the pcm be able to adjust fuel mixtures, or would its program have to be adjusted.
Dont want to run rich on idle on lean on WOT
Old Feb 8, 2004 | 01:49 PM
Mystic95Z's Avatar
The Injector Constant in the PCM must be changed or you will run rich.
-Tony
Old Feb 8, 2004 | 01:58 PM
GREGG 97Z's Avatar
Re: can PCM adjust for 28lb injectors?
Would these be 28lb LS1 injectors by chance?
If so I asked about using them in an LT1 recently and the general consensus was it wasnt a good idea as a performance upgrade. If they are LS1 injectors I would do a search on them and see what people say.
Old Feb 8, 2004 | 02:03 PM
Kain's Avatar
You could, I had a friend run 30#'ers (flowed for 45 psi). Correct me if I'm wrong, arn't LS1 injectors flowed for 60 psi?
Anyway, you'll run pig rich. IMO, get the programming.
Old Feb 8, 2004 | 03:19 PM
QCKZ28's Avatar
LSI injectors are rated at 58psi, LT1 injectors are rated at 43.5psi
you will definately need you PCM reprogrammed for different size injectors.
jesse
Old Feb 8, 2004 | 03:47 PM
med_reject's Avatar
I didnt think of putting in ls1 injectors. IM running 45psi. I was hoping that 28 is close to 24 (stock), so the pcm might be able to adjust the pulsewidth accordingly.
Old Feb 8, 2004 | 04:16 PM
RE AND CHERYL's Avatar
What cam are you using? If it's something like a Hot cam or CC305, I would just install the cam and go. The stock injectors cam supply enough fuel for those cams and the ECU can handle them without programing. It will run better with programing though.
Don't install the injectors without reprograming the ECU.
Old Feb 8, 2004 | 10:42 PM
med_reject's Avatar
Its a cc304 (waste of money) with 1.5rr, i intend on putting 1.7s in.
Old Feb 9, 2004 | 11:18 AM
QCKZ28's Avatar
your stock injectors will work just fine, no need to upgrade
jesse
Old Feb 10, 2004 | 03:46 AM
mastrdrver's Avatar
I think the LS6 injectors flow the same as stock LT1 injectors when put under the LT1 pressure.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
thenewkid
Apr 12, 2015 07:42 PM
