Can the opti timing cover gasket be replaced W/O removing cover?
Old Aug 1, 2010 | 11:55 AM
jethrobodean's Avatar
I have a oil leak coming from the opti timing cover gasket..Can I replace the gasket with out removing the timing cover?? if so HOW? How do you get it out?
Old Aug 1, 2010 | 12:04 PM
old93camaro's Avatar
yea it can be done you can use a screw driver or go buy a seal puller
Old Aug 1, 2010 | 12:06 PM
you pry it out with the screw driver? Man I dont want to screw up the cover....
Old Aug 1, 2010 | 12:33 PM
RamAir95TA's Avatar
A seal puller will work fine.
And it's not a gasket, it's a seal.
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 29, 2014 04:54 PM
Snoman73
Nov 17, 2014 07:22 PM
