can a machine shop do this?
Old Feb 14, 2007 | 03:32 PM
streetrod93's Avatar
yesterday i was torquing down the cam sprocket bolts when one of them broke off in the cam. none of the bolt is sticking out and i don't want to beat on the end of the cam with an easy our or something like that.
what i was wondering is if a machine shop would have a way to exctract the screw without damaging the cam?
thanks,
-jeff
Old Feb 14, 2007 | 03:34 PM
red83's Avatar
yes they can
Old Feb 14, 2007 | 07:57 PM
toolmaker's Avatar
Try a pick to see if you canmove it or a small center punch and tap it around, if you just twisted it off it should come back out pritty easy unless its cross threaded. Good Luck
Old Feb 16, 2007 | 05:04 PM
matLT1's Avatar
Why do you need to tap the bolt to use an easy out? The ones I have used always specified a drill bit size that you were to use to get a hole going in the broken bolt. Once the hole is drilled, insert your easy out, rotate it counter-clockwise and the easy out should bite into the hole you have drilled.
Old Feb 16, 2007 | 05:14 PM
SStrokerAce's Avatar
Take it to a machine shop and have them get it out so you don't screw up the cam.
Bret
Old Feb 16, 2007 | 06:03 PM
toolmaker's Avatar
easy out's are a last resort, most people can't drill a hole straight or in the center witch then recks the thread.
streetrod93,
If you want you can send the cam to me and I'll take it out if you have'nt got it out yet.
Old Feb 16, 2007 | 06:51 PM
thanks guys, machine shop yanked it out yesterday....easy job
93 RedBird
Nov 15, 2015 08:24 AM
Hal Fisher
Sep 30, 2015 09:03 PM
drt
Sep 27, 2015 04:39 PM
Z Power
Sep 19, 2015 11:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
