Can I use Comp BBC 1.7 ratio rockers...
...if I convert to 7/16" studs? Do I need a different OD spring, or will a standard set of 987's or Isky's work?
I'm referring to CC Part#'s 1411-16(Magnum) and/or 1320-16(Pro-Mag)
I'm budget limited at the moment plus I'd like to prolong having to tear apart the front of my motor for a bit longer. Currently I'm stock cammed with 1.6's. Am I wasting my time with stock heads? TIA
Why a BBC rocker when you can use a SBC 1.7 ratio rocker like a Crower?
Yes, you can run one once going to a 7/16 stud.
No, won't have an effect on the valvespring OD required. The 987's will work as will any other brand that's correct for the spring pocket diameter being used.
-Mindgame
-Mindgame
Many bolt on nuts use those rockes, but valve cover clearance has to be a issue. I would use a 7/16 stud no matter what, its one of the mistakes I made
. Standard spring should work but should have higher lift capability. I would just get 1.6s/ crane springs 10308 (I think) and then your ready for cam anyway. 1.7s also would give more false knock. Rocker will help in any head.
Bill
. Standard spring should work but should have higher lift capability. I would just get 1.6s/ crane springs 10308 (I think) and then your ready for cam anyway. 1.7s also would give more false knock. Rocker will help in any head.Bill
Thanks for the quick replies.
7/16" studs are a definite, as are new springs. I half assed it the first time around and I'm lucky not to have broken anything so far. I'm not a redline nut like some, I prefer the 3500-5200 range when I'm driving "hard" so midrange is what I'm after mostly. My limited understanding of cam dynamics says that short duration with higher lift (ie: what I would get off the stock cam with lots of rocker ratio) will net me the midrange power that I want.
That being said, what vendors are offering Crower products currently?
Nayr
Mar 3, 2023 08:34 PM
