Can I use 2 different spark plugs?
Old May 12, 2005 | 07:00 AM
SNEAKY NEIL's Avatar
I am about to change my spark plugs from NGK TR6's to Bosch Platinum plugs. The NGK's are pretty old and need to be replaced. My problem is, I hate changing the plugs and I might not finish this in one day (I have other stuff to do) so would there be a problem running the 2 different plugs for a few days until I complete the swap? Thanks.
Old May 12, 2005 | 08:22 AM
luckyou03's Avatar
Re: Can I use 2 different spark plugs?
I did that on a different car I had. It was a v6 and it had 3 ngk on one side and 3 bosch on the other side. Ran fine for like a year.
Old May 14, 2005 | 08:50 PM
Thomash's Avatar
I agree no problem. You should be able to run a different brand plug in each cylinder for years, But I don't know why. I know guys with old high milage cars that have a cylinder that has worn rings/valve guides that will run a hotter plug in that cylinder. I knew one guy that claimed he got a plug for a two stroke lawn mower to fit in his real old car that was using oil. The two stoke plugs are hotter and are less prone to oil fouling.
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
