Can I take off TB without replacing all gaskets?
Old Mar 6, 2004 | 04:24 PM
b-stevens's Avatar
Well of all the places I've called the only gaskets anybody has in stock are the TB to intake gaskets, can I take the throttle body off and only replace this one and be fine?
Old Mar 6, 2004 | 04:35 PM
carlos64030's Avatar
UHHHHHHHHHHH...if you're only removing the throttle body, that's the only gasket you need to replace.
Old Mar 6, 2004 | 04:38 PM
b-stevens's Avatar
well isnt there a top and bottom gasket as well? I realize the top one wouldnt be necessary but how about the bottom?
Old Mar 6, 2004 | 05:10 PM
Fastbird93's Avatar
Depends on the condition of the gaskets. I've had my TB's off and back on without replacing the gasket several times.
If you're talking about taking the IAC housing and the TB plate on top off of the TB itself, then you'll may end up needing to replace those. The IAC housing moreso than the TB plate.
Old Mar 6, 2004 | 05:11 PM
b-stevens's Avatar
Thanks, thats what I was thinking. I guess I'll just try to clean it out as much as I can without taking it off.
Old Mar 6, 2004 | 05:19 PM
Robs97Z28's Avatar
the iac uses an o-ring, if you are careful you can reuse it. as long it isn't hard or broken you shouldn't have any troubles.
Old Mar 6, 2004 | 05:24 PM
b-stevens's Avatar
Im pessimistic
Old Mar 6, 2004 | 05:27 PM
Fastbird93's Avatar
I wasn't talking about the IAC O-Ring. That thing is a pain, and you can't find it anywhere. If it crumbles (which it probably will) just go to the auto store and buy a roll of gasket material and cut a new one.
I was talking about the IAC housing on the bottom of the TB.
rick350
Mar 16, 2015 02:59 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
