Can I remove key from the crank?
Old Sep 17, 2005 | 05:45 PM
djm_e22's Avatar
I just realized that my new crank has a key but the LT1 hubs don't. Since I won't be using a supercharger can I just somehow remove the key from the crank and install my hub? Also could I have done any damage to the crank when I was trying to beat the hub on? I did cause the key in the crank to move up somewhat. I don't see anything visible to the crank I just figured that maybe I could have, but hopefully not of damaged the crank.
Old Sep 17, 2005 | 06:24 PM
Re: Can I remove key from the crank?
There should be a front and rear slot on the crank for keys. No key is needed on the front slot. The rear one is needed for the crank gear.
Heathen1
Jan 2, 2016 04:27 PM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
