can i re ring and install new mains on my LT1
Old Apr 7, 2003 | 03:18 PM
1994TransAm's Avatar
hi there,
i have another motor...i wanna just freshen it up....no 383's.... the block has been hot tanked and clean.... fully dis assemblied...comes with crank and rods, and pistons...
so can i re ring and reuse them if they check out okay at the machine shop?
Old Apr 7, 2003 | 03:46 PM
95CamaroZ-28's Avatar
There shouldn't be a problem as long as everything checks out ok. You should go ahead and go with new bearings(main, rod, and cam), rings, oil pump, timing set, rod bolts, head bolts, and of course you'll need all new gaskets and such.
HectorM52
Jul 30, 2017 11:46 AM
1963SS
Feb 6, 2015 10:05 AM
importkiller94
Parts Wanted
Jan 17, 2015 07:23 PM
Fedesna
Nov 23, 2014 11:06 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
