Can I pull a Valve without removing the head?
Old Aug 1, 2005 | 10:56 AM
gamecockfan04's Avatar
I hate too keep posting about this, but everytime I look at the head I dread having to pull it. I have a valve that is making a bad clacking noise and when I remove the push rod the sound goes away, but I have a miss. I put new lifters in and then somehow bent the pushrod on the very valve thats clacking, so Im wondering if I bent the valve, or what, but its just that one valve(3rd from the back, pass. side on #6). Can I just use a spring compressor and pull the valve out from the top?
Old Aug 1, 2005 | 10:59 AM
95_LT1_6SPD's Avatar
Re: Can I pull a Valve without removing the head?
Nope, head must come off. Are you sure its the valve clacking, and its not a loose rocker or something?
Old Aug 1, 2005 | 11:01 AM
btchincamaro's Avatar
Yes, but its a lot of work. You have to lift the motor to drop the pan. Then unbolt the rod cap so you can separate the rod from the crank. Pull the piston out the bottom, then use the spring compressor to release the valve and pull the valve out through the bottom of the motor.
No, just pull the head.
Old Aug 1, 2005 | 11:02 AM
CheshireCat's Avatar
There's no way to pull a valve without removing the head.
Well technically I suppose you could remove the entire rotating assembly and let the valve take the valve out throgh the block, but that would just be silly...
Old Aug 2, 2005 | 02:53 PM
arnie's Avatar
Originally Posted by btchincamaro
Yes, but its a lot of work. You have to lift the motor to drop the pan. Then unbolt the rod cap so you can separate the rod from the crank. Pull the piston out the bottom....
Forgot one detail, you won't get the piston past the crank.
Old Aug 2, 2005 | 03:29 PM
1racerdude's Avatar
Just a wee small detail that makes it undoable.
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
Chris Anderson
Jan 27, 2015 08:30 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
