Can i lift the motor here?
Old Mar 20, 2009 | 11:05 AM
dubbsix's Avatar
Those of you who say you can change the oil pan gasket without lifting the motor... you guys are magicians!
I have to lift my motor, but i've searched and I havent found a single thread that shows good aka safe places to lift the motor from.. aka lifting points.
Is it safe to screw in a bolt into the accessory bolt holes in the heads? ( my worry here is soft aluminum)
Or is it better to screw a bolt into the block and lift from there?
Old Mar 20, 2009 | 11:22 AM
86camaro383's Avatar
your fine. you can lift there. just make sure the bolt is on all the way!
Old Mar 20, 2009 | 11:52 AM
87bandit's Avatar
I'd rather run a bolt into the block but that's just me
Old Mar 20, 2009 | 04:41 PM
dubbsix's Avatar
Right.. is there a grade of bolt i should use? grade 8?
Old Mar 20, 2009 | 04:56 PM
MTBSully's Avatar
i jacked min from right under the timing cover and had no problem pulling the entire pan and replacing the gasket
Old Mar 21, 2009 | 12:06 AM
dubbsix's Avatar
wow.. living on the wild side huh.. not really willing to take that risk. Heard rumors of missing digits relating to jacking up the motor there.
Old Mar 21, 2009 | 01:03 AM
ENRKyle20's Avatar
I am in the same battle as you, working on gettin the pan off with the motor in the car. I am replacing the rear main tho, so I have the trans out. then I removed both motor mount bolts. then I just hooked two ratchet straps around the center two header pipes, its plenty strong as my second picture shows.
the big tow rope is just there so when the car falls on me it will take longer to kill me. lol. I was on the cherry picker so i hooked it on. lol
Old Mar 21, 2009 | 10:18 AM
dubbsix's Avatar
Thanks for posting the pic. I thought about wrapping a strap around my headers, but i havent installed them yet. I think im going to go with a bolt through block on each side to lift it up.
Old Mar 27, 2009 | 05:01 PM
dubbsix's Avatar
Anyone have pics of their engine with 2x4's in between the motor mound and the cross member? Is it safe? Im trying to change my oil pan gasket, but with the legs of the hoist underneath the car its almost impossible. help!
Old Mar 27, 2009 | 05:45 PM
ENRKyle20's Avatar
I put the back up on ramps, then supported the front of the car off the ground with jack stand, then I layed directly under the trans, the legs didnt get in my way much.
if you REALLY need to get it out of there then make something using this design. this is made to support the engine (usually FWD, while you take the transaxle out). you can do it with a chunk of junk metal or maybe even wood.
Old Mar 27, 2009 | 06:18 PM
dubbsix's Avatar
Thanks.
Old Mar 27, 2009 | 06:37 PM
ENRKyle20's Avatar
no problem. they make several diffrent kinds.
Old Mar 28, 2009 | 12:04 AM
dubbsix's Avatar
I thought about using these, but with my car's nose in the air..i thought it would be hard to maintain proper balance of the engine cradle.. since it would essentially be mounted at an angle..
LeftoverChinese
Jan 14, 2024 03:03 PM
MyfateZ28
Jun 19, 2015 03:42 AM
Cam's maro
Jan 30, 2015 09:21 PM
edman
Jan 25, 2015 02:41 PM
kandied91z
Jan 23, 2015 11:14 AM
