Can I go bigger than a gm847 on stock heads?
Old Jun 21, 2005 | 06:47 PM
  #16
Kurt Crosbie's Avatar
Re: Can I go bigger than a gm847 on stock heads?
Yes, I do have stock heads, and I don't plan on dishing out over 1000 dollars for ported heads any time soon
Old Jun 21, 2005 | 07:33 PM
  #17
SStrokerAce's Avatar
Well considering that the fastest M6 bolt on guy just had me design a cam for a him so he can go after the fastest t"cam only" time.... I have a very opinionated view of it. The cam was smaller than the GM847 and bigger than the 218/224 LR mentioned.
BTW if you want to see some TQ and HP curve comparisons of that big Joe O cam and what I would consider the right cam with pretty equal ported heads... I'm willing to share. The TQ curve will speak for itself.
Bret
Old Jun 21, 2005 | 08:57 PM
  #18
97Z-M6's Avatar
Originally Posted by chy20k1
le3 includes ported heads, this guy has stock heads
if you read the origanal post its says he has stock (homeported heads).
brett. im not trying to start one of those old joe O threads. trust me.
there is a car on his website its a full weight TA. that put down 428 rwhp, through a 2 speed power glide, and a 12 bolt on a stock bottom end with 100k on it. and ran 11.05 at 120. i know the cam specs of that car. and they are not smaller than the 847. yes he has about everybolt on you can think of.
and theres also someone running 11.7x on one of his cam that is only 2 degrees bigger than the hotcam.
i personally dont care about rwhp and torqe give me track times.
by the way what is the fastest 6speed camed car record and does camed car mean ported heads or stock untouch castings?
i do agree you dont have to go big to make power but if you want to make the most power you can its going to be bigger than the 847, even on a stock bottom end, personlay i would not go bigger than the 847 on stock untouched heads.
good luck on that goal bret
Old Jun 21, 2005 | 10:16 PM
  #19
Ain't my goal boss... I just get asked to supply my knowledge. Thanks either way!
I liked the thread with Joe BTW.... when someone calls me out it's about the only time I actually care enough to write something with some meaning on here.
stock untouched castings.
Well the most power I can for me is the most average power in the useable RPM band. For drag racing that should be the highest useable RPM band that you can run the motor in, and the most average power in that RPM band.
There is always such a thing as too much cam too.....
Bret
Old Jun 22, 2005 | 12:02 AM
  #20
roadtrip120's Avatar
Auto record Frank95z
1995 Z28, stockheads ,A4,52TB, cold air,hooker longtube headers,Crane 210/224, 1.6rr,Strange 12bolt,QT Pros, Vig3200.
1/4: 11.40 at 116.59
60 ft:1.483
M6 record atljar
Best 11.98/115.44/1.68, NA,
w/stock heads, 357rwhp
Cam only is cam only, no head work what so ever
Then compare auto to auto, m6-m6 , weight to weight. Apples and *** holes is not a good comparison. Also peak numbers are not everything you have to look accross the board.
Shouldn't be that hard, a better night with my bolt-on car could break into the 11's. If not, then a pos hotcam could do the trick. But i wanted the best cam for my setup, so i went to the guy that could do that for me. I didn't just want to beat the record , i wanted to smash it. Try and make you other f-body owners work a little. Its no fun if there is no competition.
See you at the track,
Old Jun 22, 2005 | 12:17 AM
  #21
Damn dude, I think if you were cammed, you could go low 11. Are you spraying?
Old Jun 22, 2005 | 12:35 AM
  #22
He does spray... but not to go that 12.2 lol
Brady is moving now as it is, so it shouldn't be too long.
Bret
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
Killer94z
Jan 13, 2015 12:06 PM
Brian-94TA
Jul 31, 2002 02:52 PM
