can I get caps to cap off the AIR pipes on 96-97 Pacesetter LTs?
Old Feb 23, 2006 | 08:44 PM
TransAm396's Avatar
Installed them tonight..and i was wondering where i could get caps to cap them off.
Old Feb 23, 2006 | 08:55 PM
IllusionalTA's Avatar
Re: can I get caps to cap off the AIR pipes on 96-97 Pacesetter LTs?
are they screw on? if so a pipe cap will work.. just find out the thread.. make sure to seal it w/ high temp rtv as well..
Old Feb 23, 2006 | 09:47 PM
LT1 POWR's Avatar
I got mine at menards in the plumbing section. What i did was brought my old stock manifold into menards and tried caps until it fit. I think it was called a M22 drain plug or something like that, but dont quote me on that.
Old Feb 23, 2006 | 09:49 PM
TransAm396's Avatar
yeah they are screw on...now if only i knew the size.
Old Feb 23, 2006 | 10:13 PM
GMRL's Avatar
On the pacesetters, I had to uses these brass compression caps on the AIR tubes.
I tried using these galvanized caps but they wouldnt screw on, even though they were the same size. I dont remember the size though.
Old Feb 23, 2006 | 10:42 PM
kingman109's Avatar
thats becaause compression is a different thread then pipe thread
Old Feb 23, 2006 | 11:39 PM
TransAm396's Avatar
where did you get em.
Old Feb 26, 2006 | 04:34 AM
My Iroc Z28's Avatar
If this helps any.. i just bought these caps from jegs for my pacesetter headers and they worked fine
-10 An Flare Cap P/N 555-110314 $7.49ea
Old Feb 26, 2006 | 09:52 AM
jchevy's Avatar
I went to lowes and bought a brass pipe cap used for natural gas. It was a 5/8" If i remember correctly.
Old Feb 26, 2006 | 01:54 PM
TransAm396's Avatar
haha thats funny..those dark ones..i bought too..didnt come close to fitting..so i found those brass ones and they fit like a glove. Got them at napa
calaban
May 18, 2020 06:43 PM
Ringmaster72
Dec 12, 2017 10:12 PM
drptop70ss
May 4, 2015 08:22 PM
95chwagon
Jan 13, 2015 09:19 PM
