Can a hotcam'ed car run out of gas?
Old Aug 21, 2003 | 01:27 PM
97Camaro007's Avatar
I mean can a hotcamm'ed car run out of gas with a stock fuel pump....I have had tuning done but it just seems to be missing up top and last time i had it dynoed it was about 14.9-15.0 Air/Fuel at about 5k rpms and up......Has anyone else had any problems with this?
Old Aug 21, 2003 | 01:32 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: Can a hotcam'ed car run out of gas?
week fuel pump id guess
Old Aug 21, 2003 | 01:37 PM
GREGG 97Z's Avatar
I've heard the stock fp can support approx 400hp (fwhp) so I don't think that's a problem for you. Your A/F ratio sounds kind of high, I have the same cam & springs and mine was around 13/1 after 5K. Your problem could also be the LT4 springs, they are supposed to be just adequate for the hotcam, not ideal. You may be getting valve float at higher rpms. I'm thinking of swapping them out for something stronger, mine car seems to drop off after 6K rpm, I thought it would still pull a little beyond that.
Old Aug 21, 2003 | 02:22 PM
Josh-'04 GTO's Avatar
Could also be a plugged filter or faulty fuel pressure regulator. What kind of fuel pressure does your car put out?
ro2207
Dec 4, 2014 06:18 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Brent94Z
Mar 21, 2002 04:44 PM
