Can exhaust leaks cause a low end hesitation???
What I thought was stripped plug holes turned out to be the stupid header bolts backing out. So I need to fix those but I want to know if anybody has found exhaust leaks to be the cause of a low end stumble. Very light load light throttle low rpm I get a stutter. Sometimes it is worse than others and sometimes it's not even there. It happened about the same time I put my headers in... That's why I think it's the exhaust leak. Is there anything else I can check? The car is very well taken care of, freshly seafoamed, new o2's, clean MAF and intake...
CARiD
Jan 27, 2015 06:27 AM
