Can the engine run with trans disengaged?
Old Jan 26, 2004 | 07:04 PM
Loadre's Avatar
Doing a tranny/converter swap and the bellhousing bolts won't even come out with air tools. Probably doesn't help the garage has been 30* for the past 2 weeks and that's where the car has been. I want to start the engine and let the block get warm to heat up the bellhousing bolts. The torque converter bolts are out and the converter is pushed back against the tranny so that it is not touching the flexplate. Would it be safe to start the engine? Would the transmission connectors have to be plugged into the tranny? Need help here.
Brian
Old Jan 26, 2004 | 07:07 PM
Heatmaker's Avatar
Advanced Member
I dunno bout the auto...4160E or whatever the fudge but my engine ran without the tranny installed.
Old Jan 26, 2004 | 07:10 PM
funina91ss's Avatar
started mine up without the trans in Man that thing revs alot faster without a converter hooked to it
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jan 5, 2015 07:14 PM
hotrodyou1
Dec 20, 2014 10:05 PM
siguy
Nov 27, 2014 10:07 AM
Lions3
Apr 11, 2003 10:55 AM
