can a engine GO from cam install
Old Aug 20, 2003 | 11:46 AM
Dmx4ever3's Avatar
Angry can a engine GO from cam install
can a engine GO from cam install cause i installed cam in sig and the shop said the the car is loseing oil pres. and a bearing or or something is bad im not sure but its a turd and they said it from having 77000 miles???
Old Aug 20, 2003 | 11:48 AM
Hyperspeed97z28's Avatar
SURE CAN..... My friend Geoff installed a cam and he said not very long after this oil pump gave a few hic up's and spun a bearing....
SO YES IT IS POSSIBLE....
Old Aug 20, 2003 | 11:51 AM
Dmx4ever3's Avatar
Unhappy
thats what happened to my car can it be fixed??? did he fix he car??? what do i do?? HOW MUCH???
dave1w41's Avatar
1. Dirt from a sloppy install.
2. Overtorqing/Mistorqing the intake manifold (distorts the block and destroys the main bearings)
Engines rarely fail from cam changes unless someone gets dirt in them or is sloppy on the install. Of course, if the engine was in poor shape putting a cam in it can kill it. An example would be a car that had 77,000 miles on it and didn't get regular oil changes.
Old Aug 20, 2003 | 11:52 AM
rob97ss's Avatar
sorry to say it but yes it can go,i installed the same cam with 56,000 miles an hour later spun a bearing.it sucks but it happens.good luck.
Old Aug 20, 2003 | 11:54 AM
Makes me not even wanna do a cam... 56k jeez, Geoff's had 120k or so....
Dmx4ever3's Avatar
could it be cause they said the oil they put in after cam install didn't need to be changed to 3000 miles
Old Aug 20, 2003 | 11:57 AM
Ken95Z28's Avatar
I never heard of over torquing an aluminum intake manifold on a iron block distorting the main bearings.
I do agree with the sloppy install and careless of installing a cam into the motor.
Old Aug 20, 2003 | 11:58 AM
How long after this cam install did this happen. I think the oil should be changed out after 300 miles then again after the 3000-3500
Old Aug 20, 2003 | 01:00 PM
dave1w41's Avatar
Very common on 4.3 V6 and Small block engines. - Not the most common cause for post-repair failure but probably #2. Just looking at the block it does not look possible but just because it is made of iron does not make it impossible. If you study some finite element analysis and some basic cylinder case engineering it becomes obvious why it happens. You would be shocked at the amount of bore distortion that occurs when you tighten down a cylinder head or even an adjacent main bearing cap. That is why a block is machined and honed with a deck plate and the main bearing caps in place. It would help if you could machine it with the intake manifold in place as well but you can't.
Old Aug 20, 2003 | 01:10 PM
Dmx4ever3's Avatar
cam install was just done and they told me the engine is now bad i think they rev the should out of it dynoing it and stuff
Old Aug 20, 2003 | 04:04 PM
Mikey97Z's Avatar
But the intake bolts to the heads! Not into the block! :blah:
Old Aug 20, 2003 | 04:15 PM
96 WS6's Avatar
LOL that's what I said...
Old Aug 20, 2003 | 04:44 PM
BUBBA's Avatar
My engine went after head and header install.
Only 8 grand on the clock.
Had cam installed with around 2 g on clock, but spun bearing with less than 500 after head installon.
Haven't a clue why it went, but I supposed that putting even 400 Hp at the crank could be too much on some engines, although there are engines with much more HP on the 2-bolts that have survived.
Glad that I have a 4-bolt now anyway. Just a bit more comfortable.
Old Aug 20, 2003 | 05:00 PM
OBDIICamaro's Avatar
Im gonna have to say the same thing on disagreeing on how the intake is put on. Yes there is a torque sequence but it is mainly for proper sealing of the intake to the gasket. In no way will it cause a Iron block to distort even a little with the heads fully torqued to spec.
The only thing is on Mustang 4.6s you have a detorque sequence because of the aluminum block and you have torqu to yield bolts that have to be throwen away each time of use.
