Can an autoxray scanner drain a battery?
Old Aug 3, 2005 | 03:32 PM
MRBoss429x's Avatar
I dont see how it could, but the first time I used it I left it plugged in and the next time I went to start my car the battery was completely dead, not even jumpable. Its probably a coincidence, but could leaving it plugged to the ALDL port drain your battery?
Old Aug 3, 2005 | 04:31 PM
Re: Can an autoxray scanner drain a battery?
Seems odd. Doesn't it automatically shut off after a while?
Old Aug 3, 2005 | 04:50 PM
JP94Z's Avatar
The manual for mine says it should power off automatically if you don't hit any buttons for 30 minutes.
I've left mine plugged in overnight and had no problems.
Old Aug 3, 2005 | 04:55 PM
mattbailey's Avatar
Mine shuts off automatically. I think it only takes about 20 minutes.
Old Aug 3, 2005 | 04:58 PM
MRBoss429x's Avatar
Im not even talking about the unit power, the cable itself. I want to leave the cable plugged in and tucked away so I can scan it whenever (been doing it alot lately). I figured it was just coincidence, just needed some backup, thanks guys.
Old Aug 4, 2005 | 11:48 PM
Mtrhds94Z's Avatar
Don't leave the auto XRay in the hot car.. I learned the hard way that the heat[and I had it covered from direct sunlight] ruined the keyboard..
I tested it and swapped the keyboard with another older one I had and it works again..
I have left just the cable plugged into ALDL port for days, and it had no effect on the car battery..
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
68camaroboltz
Oct 5, 2015 01:46 PM
plattted
9
Sep 20, 2015 11:23 AM
jackpawt883
Sep 10, 2015 08:53 PM
