can 96 LT1 stay running if battery removed ?
Old Jun 15, 2010 | 06:46 PM
  #16
Mir Hussain's Avatar
Thumbs up
Originally Posted by ChickenScreamer94
Yeah, I wouldn't try to do this. Your alternator is just there to replenish the lost power from starting, and give a little more to run accessories. It will most likely kill itself after 150 miles of use like that. Either overheat or fry - both? You can report back if you want
Originally Posted by dangalla
the same exact thing that happens when you have a low battery charge condition or even just high load on the system - maximum alternator output. sure it could be bad for a long period of time but its really nothing different than normal operation
you will have no problem at all with the battery disconnected long enough to swap the battery - if it stays running
but, the better option would be to just remove the battery and charge it on a low amperage setting for a long time. if it is so dead that jumper cables are not helping chances are that the battery is just no good - and driving around is not going to help you or the battery.
okay I had to drive about 50 Miles today,
So I jump the battery from a Good Battery ..... But no Go
Then I plug my portable Jump Kit.
Then it slowly turn ...... then booooom ..... with one or two cough....
barha barha barha .....
It started to idle...... I removed the Good battery and Jump kit.......
Now car running off its own and charging dead (almost) battery......
Turn on the Stereo.. A/C ...... and drove it........
.... Drove it for 17 Miles
Stop it kill the engine....... did some office work..........
came back after 15 min........ car started back up like it never had a dead battery .............
I guess........ it charge the battery up........
Did few other stops no problem.......
Thanks guys for advise...... I am glad I didn't drove it without battery and end up frying the electronics
Gtpguy
Jan 26, 2015 04:50 PM
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
Fedesna
Nov 23, 2014 11:06 AM
F(ast)-body
Feb 26, 2003 09:05 AM
