Can a 95's opti be used on a 94?
Old Sep 15, 2004 | 10:38 PM
9T4Z28's Avatar
I got a 95 opti for my 94, got it for free so no regrets lol, but the mechanic said it would not fit, is this true?
Old Sep 15, 2004 | 10:43 PM
GreenDemon's Avatar
Re: Can a 95's opti be used on a 94?
My advice is to see how much $$ you can get for that opti and just go with a delteq or ltcc. There's too much stuff to change to even worry about it now that there are better things on the market. Someone with a 95-97 may offer you some decent cash for it if it's in good condition and theirs is on the way out.
Old Sep 15, 2004 | 10:48 PM
indieaz's Avatar
yah, first of all your dowel pin on your existing camshaft will be too short to drive the newer style opti (our 94s are gear driven...not driven off the cam dowel)
. So that would need to be changed. Then you also need some additional hoses (the 95+ are vented and have a tube that runs from the intake manifold and to the intake elbow).
Old Sep 16, 2004 | 12:05 AM
A lot more than that needs to be done to convert to a vented opti.
Old Sep 16, 2004 | 12:41 AM
9T4Z28's Avatar
I just bought a new opti for 150 + shipping , my friend found it on some site he has, hes a mechanic, hopefully this all works out, its been one thing after another.
Old Sep 16, 2004 | 01:48 AM
camarokid24's Avatar
Sounds like a good price, yeah you are going to need a diferent cam and timing cover, might need a new timing chain kit as well. Most people convert to the vented opti when they are changing cams. Unless your water pump takes a dump on the unvented opti or you drive through 2 feet of water they seem to be as good. You just get the added bonus that if it gets wet the vent will help dry it out. Unless you are planning on changing the cam I would just get the 94 opti. I know they are more expensive but will be less money less work. good luck , I would check out shoebox's site out he's got a lot of great info into what you would be getting yourself into on converting to vented opti
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
