Can a 95 Z be out of time ?
Old Jul 17, 2005 | 07:20 PM
chuckys95's Avatar
I have a 95 Z28 LT1 and when i go to start it, it seems like it "grunts" to get started. is there a way that it can be out of time? or is this a sign that the opti-spark is going bad?
btw, i have a new Optima red top battery in it.
thanks!
Old Jul 17, 2005 | 09:04 PM
Re: Can a 95 Z be out of time ?
It can't be out of time in the same sense that a rear mounted SBC distributor engine would be, if that is what you mean. Does it run ok after it starts? Need more description.
Old Jul 17, 2005 | 10:11 PM
chuckys95's Avatar
yeah, it runs fine after it's started.
it's just the startup thing that's got me puzzled.
Old Jul 17, 2005 | 10:14 PM
Without more description, starter or battery cables could be suspects.
Old Jul 17, 2005 | 10:37 PM
rdavis93's Avatar
Optima batteries haven't been good to me. Most ppl have no prob with them though. I think it might be the Advance Auto parts that I got the batteries from.
Old Jul 17, 2005 | 10:49 PM
chuckys95's Avatar
uh oh!
that's where i got mine from...
Old Jul 18, 2005 | 12:51 AM
Car Enthusiast's Avatar
do you mean it will fire, then pause then continue running cause mine does this also, and i would love to figure out why mine acts this way, also mine seems hard to start as in i will let the fuel pump prime then if i don't finagle the ignition the right way it will not turn over but if i feather the ignition at first and let off real quick i can get it to run
Old Jul 18, 2005 | 09:43 AM
That sounds like an ignition switch adjustment problem or a switch about to go out.
Old Jul 18, 2005 | 07:10 PM
how do you adjust the ign switch
Old Jul 19, 2005 | 12:13 AM
Look at the ignition switch R&R on my Tech Page. That should give you some info.
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
