Can a 93 oil press. Be converted to a 95
Old Dec 17, 2007 | 08:38 PM
windsma's Avatar
can a 93 oil pressure sensor wire be converted to a 95 unit?
My 93 broke when i removed the engine, the replacement LT1 is a 95 and has it still attached.
also
What is the Wire Plug in the tail shaft of my 93' 4l60
What is it, how important is it?
The wires got pulled out of the plug when i removed the engine.
I will buy a pig tail later but i want to crank and test drive the new engine.
Answer: NO, the sensor is different inside. It will give you a false reading
But Yes, the pigtail is the same.
On a 93 z28 The oil pressure switch/sensor is connected to the Fuel pump, no oil press. the fuel pump will turn off.
Old Dec 17, 2007 | 08:45 PM
96m6lt1's Avatar
Originally Posted by windsma
can a 93 oil pressure sensor be converted to a 95?
also
not too sure about the sensor,i do know the instr.clusters are different and will not function properly in a 94-97...
the wires you pulled out are for thr VSS(vehicle speed sensor)you will want to repair that so your speedo will work and the transmission will lock-up....
Old Dec 17, 2007 | 08:47 PM
windsma's Avatar
what do you mean by lock up?????
and does the ECU require the oil pressure sensor be working for the engine to run properly?
Old Dec 18, 2007 | 02:07 AM
96m6lt1's Avatar
when your car goes into 4th gear you will notice shortly after the gear engages the RPM will drop an additional 2-300 rpm that is (converter lock-up)....
Old Dec 18, 2007 | 07:18 AM
The oil pressure sensor should not be a problem and the computer is not fed oil pressure information.
Old Dec 18, 2007 | 10:15 AM
windsma's Avatar
Thanks , u too Shbox.com
A new 93 oil pressure unit from the dealer is $78 no thanks. Ill find a used one. or figure out how to use the 95
I have one on the way i just wanted to test drive it after the engine breakin
"I love the headlight pockets on my 93 they are like tool shelves."
Old Dec 18, 2007 | 01:04 PM
My93Z's Avatar
If you use the 95 oil pressure unit you will also need the 90* bend. The plug that is on the top of the block should fit where the 93 oil pressure unit goes. I can't remember if the pig tail is the same but I think it is, just remove the rubber cover.
Old Dec 18, 2007 | 03:49 PM
Dennis93TA's Avatar
I went to auto zone with the old one in my hand and mactched it up. I don't remember exaclty how much it was but i want to say around 20 bucks. I broke mine when putting in my long tubes.
Old Dec 19, 2007 | 10:04 AM
windsma's Avatar
the rebuild engine is a 95 LT1 and has all the stuff i just wanted to know if anyone had been able to convert it the wires.
But if they are that cheap at auto zone ill just buy a new one. my 2nd water temp sensor also snapped off. WTF are these bastards made of.
Old Dec 19, 2007 | 03:24 PM
windsma's Avatar
I pulled back the stupid rubber thing and there is a plug under there. Who knew. I thought it was on big unit. I unpluged it and it does fit the 95' once i get it started ill tell u you if it works. Im haveing a no start issue and the gauge goes all over the place when i starting it.
Old Dec 21, 2007 | 10:52 AM
windsma's Avatar
answer in first post.
I bought a new 93 oil press. at advance auto for $27
captcorvette
Mar 7, 2015 12:37 PM
ChrisFrez
Feb 15, 2015 07:49 AM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
