Can 02 wires blow ignition fuse?
Old Feb 19, 2005 | 04:18 PM
Sweetred95ta's Avatar
I found that the wires that are bundled up in silver wrapped heat taped, that run next to the header on the passenger side, were burnt through a little bit. Two of the 02 sensor wires were stuck together. Could this cause an ignition fuse to blow or even make the car run like crap or not at all?? I'm trying to narrow some stuff down with the diagnosis of my car. Any help is appreciated.
Thanks,
Benji
Old Feb 19, 2005 | 05:13 PM
Re: Can 02 wires blow ignition fuse?
The O2s on your car are powered by the FANS/ACTR fuse. If your O2 is not working, it's not going to run right.
Old Feb 19, 2005 | 10:29 PM
Would it cause the car to miss horribly? This sheading light on the problem. Except I can't figure out how I blew an ignition fuse. Thanks for the reply.
Benji
Heathen1
Jan 2, 2016 04:27 PM
eanhl2004
Apr 4, 2015 12:01 PM
jayvar
Feb 2, 2015 10:00 PM
Ari G
Dec 11, 2014 03:21 PM
